Group: DynoMotion Message: 9834 From: toolhoarder Date: 7/22/2014
Subject: Can I use a 48V Regulated PS With my Setup?
Hi, I'm new here.
I am trying to pick a power supply for a Kstep/Kflop combination. I just found out that a regulated supply would be best, so I am looking for one. I want a lot of current on tap because I would like to have the option of adding a second board so I can hook a mill (4 axes) to the same system. The first machine will be a mini-lathe with two 425 oz-in motors. I do not plan to try to run both machines at the same time.
I am considering a 48V regulated supply that puts out 12.5A. My wall voltage runs 125 all the time, which is a little high. I am concerned that the supply may go over the 49.5V line and cause problems with the voltage clamp. I don't know much about that; I just know it's BAD.
Wondering if anyone can advise me. The motors I have now are Keling KL23H286-20-8B steppers. They are rated at 2.8A and 4.17V in parallel, and the resistance is 1.5 ohms.
Group: DynoMotion Message: 9843 From: Tom Kerekes Date: 7/23/2014
Subject: Re: Can I use a 48V Regulated PS With my Setup?
The wall voltage should have little effect on the output voltage of a regulated supply.  The voltage should be less than 48.5V actually.  Check with a voltmeter before connecting.  Some supplies have an adjustment potentiometer.
48V at 12.5A is 600W of power.  That should be sufficient.  Each Stepper should always use less than 100W.
Group: DynoMotion Message: 9845 From: toolhoarder Date: 7/23/2014
Thanks again.
